System RED ground wire - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org/mybb) +-- Forum: Public Forums (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=30) +--- Thread: System RED ground wire (/showthread.php?tid=4276) |
System RED ground wire - Henrik.Jessen - 2026-08-12 Hi I have moved to a new adress and setup my System RED. Unfortunately the ground wire lost its connection to the board and I dont know where to connect it. It looks like it was soldered to the backside of the bord, but I might be wrong. I have attached photos of my board. Right now I have connected it to the bolt/nut on the backside. Hope someone can guide me in the right direction. Kind regards, Henrik from Denmark RE: System RED ground wire - Hoelters - 2026-09-22 Yes, so it is Ok too |
