GPS LED sytem blue mini
just started: Gps LED blinks. Is this okay?
station# 3309
(11 hours ago)gerardvtk Wrote: just started: Gps LED blinks. Is this okay?
station# 3309
At about once a second? Then on my BLUE that means the 1 PPS is working.
Station 2828 - LM or BT
Stations: 2828
Your station is sending data but you did not set the antenna type in your config panel online. This is important for the servers to know how to 'read' your signal. Each antenna has other signatures.
From what I can see your GOPS is doing fine and you can see that in your local panel, it shows the number seen and the status
