PCB 19.5
I just received my kit, systhem blue. The main PCB board is the 19.5. In the documentation (see link below), there is no mention of this board, only 19.4 and earlier. I assume the instructions for the 19.4 applies to the 19.5. Is that correct or is there any thing new that I should know about?
Thanks
https://docs.google.com/document/d/1KzPZ...1518869464
P.S. if any body has a picture of a complete mounted PCB 19.5 to post that would be very usefull.
Any difference is minor.  Wekcome aboard!
Thanks for the fast response cutty!
Welcome aboard.
Here is a picture of my 19.4 which has a similar layout as the 19.5
We have replaced the GNSS module of 19.4 because it was discontinued and no longer available. At 19.5 we use the "ublox MAX-M8W" modul. That is the only difference.
  Ethernet speed connection 10/100 on PCB 19.5 lyova 6 41,928 2020-03-07, 22:12
Last Post: mwaters
  System Blue PCB 19.4 vs 20.6 dhitzigrath 6 51,659 2019-11-22, 04:48
Last Post: kevinmcc
  PCB 19.3 Coil whine? Polyphemus 4 42,325 2016-12-08, 15:47
Last Post: Polyphemus
