Threads: 55
BO's live vector map can now be easily integrated on websites with a fixed map. The easiest way is as iframe. Here is an example.
http://map.blitzortung.org/mapexample.html
The various parameters are self-explanatory.
The following parameters with the values 0=false and 1=true are for the controls.
interactive 0/1
NavigationControl 0/1
FullScreenControl 0/1
ScaleControl 0/1
Advertisment 0/1
InfoDiv 0/1
Cookies 0/1
The settings in the menu can be controlled with the following parameters:
MapStyle 0-3
MapStyleRangeValue 0-11
Lightning Range 1-2 1-2
LightningCheckboxChecked 0/1
CourseRangeValue 0-10
CourseCheckboxChecked 0/1
CountingRangeValue 0-10
CountingCheckboxChecked 0/1
CirclesRangeValue 0-10
CirclesCheckboxChecked 0/1
SpeedRangeValue 0-10
SpeedCheckboxChecked 0/1
LinksRangeValue 0-10
LinksCheckboxChecked 0/1
Detectors Range 0-12
DetectorsCheckboxChecked 0/1
CoverageRangeValue 0-10
CoverageCheckboxChecked 0/1
DayNightRangeValue 0-10
DayNightRangeValue 0/1
AudioRangeValue 0-10
AudioCheckboxChecked 0/1
RegionRangeValue 0-9
RegionRangeValue 0/1
Have fun!
Egon
Threads: 11
thanks for sharing the fun Egon
Threads: 2
Super and can you change the location there?
and zoom
Threads: 55
2019-12-17, 20:47
(This post was last modified: 2019-12-17, 20:49 by Egon.)
(2019-12-17, 20:08)brzanek Wrote: Super and can you change the location there?
and zoom
Yes, remove interactive and NavigationControl, or set it to zero.
The initial position and zoom is set by #3/40/15 (zoom 3, latitude 40, longitude 15).
Threads: 16
Maybe an noob question. But what do I wrong when I copy and past the code to my site https://www.onweeractueel.nl/index.html
Threads: 11
putting a non secure iframe in a secure page (http in https)
browsers block this now as a standard security measure.
Unless Egon install a security certificate on the map page .... not much you can do I think
Threads: 64
(2019-12-25, 19:40)Phoenix-Blue Wrote: Maybe an noob question. But what do I wrong when I copy and past the code to my site https://www.onweeractueel.nl/index.html In Header, instead of
Code: <html lang="de" style="margin: 0px; padding: 0px;">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
</head>
Make it
Code: <!DOCTYPE html>
<head>
<title>Phoenix Blue Page</title>
</head>
Threads: 55
It now also works via "https".
The remaining websites are still being converted.
Threads: 0
first of all thank you very much for the possibility of the Live-Map, great thing!
While defining the URL I noticed that the parameter "RegionRangeValue" can be defined twice. - Is that correct?
Or in other words, could someone post an example for the definition of the desired region!?
Thank you very much!
Greetings
Rainer
Threads: 0
I've a little problem.
Have anything changed for the variable "MapStyle 0-3"?
I can't see any differences between the values at the start of the request.
It comes always up with 'MapStyle=0'.
I've cleared the cache in different brouwsers everytime for the request!
I don' have any idea what's going wrong ...
Greetings
Rainer
Threads: 3
(2020-07-20, 09:23)rf-leo Wrote: Hi,
Greetings
Rainer
I have also noticed the same behavior for a few days now. Seems to have impacted other parameters including detector links. Tried different devices/browsers clearing cache etc. Looks like something on the back end has changed.
Threads: 0
I have also noticed the same thing in the last few days.
'Detector links' are not displaying properly when requested and also "Advertising" is being displayed even though "Advertisment=0" is contained n the http request. (I hate those ads from GEICO  )
I suspect there may be a backend problem as this app has been working 100% for many months. (and we do love it!)
Thanks for looking into it.
Kind regards,
Byron (harwichweather)
Threads: 3
(2020-07-20, 22:14)Sleepypup Wrote: (2020-07-20, 09:23)rf-leo Wrote: Hi,
Greetings
Rainer
This issue seems to be resolved now. At least for me it is working as expected again on all devices. http://nwrweather.com/
Thanks to whoever resolved it.
Dean
Threads: 0
Looks like it’s now working correctly for me as well.
Thanks for fixing it.
Stay safe...
Threads: 0
Hello
I use iframe of Blitzortung map on my weather site ( https://meteo-auffargis.decoodt.eu "Foudre et éclairs" tab)
At each time I go to this page I have a window "this site use cookies" and the answer is not memorized on the computer or mobile. ALso whe I return to this page, I have always this window!!
I have tested cookies=0 in iframe line, but no effect.
Do you have the same problem?
Have you a solution?
I hope that I am on the right part of forum.
Thank's a lot for your help
Threads: 64
2020-12-06, 17:02
(This post was last modified: 2020-12-06, 17:08 by cutty.)
(2020-12-06, 15:42)ddperso Wrote: Hello
I use iframe of Blitzortung map on my weather site (https://meteo-auffargis.decoodt.eu "Foudre et éclairs" tab)
Thank's a lot for your help Code: <!DOCTYPE html>
<html lang="en">
<head>
<meta name="viewport" content="width=device-width,initial-scale=1">
<meta charset="utf-8">
<meta name="dcterms.created" content="Sun, 06 Dec 2020 16:50:02 GMT">
<meta name="description" content="">
<meta name="keywords" content="">
<title></title>
<style>
#hedd {z-index:20;position:relative;height:306px;margin-bottom:00px;
border:.2vw solid #909090;
border-radius:23px;
margin-left:0;
width:406px;
#hedd iframe {
display: block; /* iframes are inline by default */
background: transparent;
border: none; /* Reset default border */
height: 300px; /* Viewport-relative units */
width: 400px;
margin-left:0px;
border:6px solid #555555;
border-radius:20px;
</style>
<!--[if IE]>
<script src="http://html5shim.googlecode.com/svn/trunk/html5.js"></script>
<![endif]-->
</head>
<body>
<div id="hedd">
<iframe name="content_frame" src=
"https://map.blitzortung.org/index.php?interactive=0&NavigationControl=0&FullScreenControl=0&Cookies=0&InfoDiv=0&MenuButtonDiv=0&ScaleControl=0&LinksCheckboxChecked=1&LinksRangeValue=10&MapStyle=0&CirclesCheckboxChecked=0;MapStyleRangeValue=10&Advertisment=0#1.72/37.1/-95.21"
id="content_frame" ></iframe>
</div>
</body>
</html>
This example should work fine if you set your variables to suit.. Convert all "&" to "&"
Threads: 0
Many thank's Cutty for this quick answer
It's works perfectly!
Threads: 5
Greetings,
I have a couple of the maps suggested on the original post of this thread on my website. For the last month or so the 'Cookies' and the 'Advertisment' specifically no longer work. I have received complaints from some of my regular visitors. Has something changed? Possibly there are new parameters or something I have over looked?
Comments and ideas appreciated.
Ralph Lee
