Threads: 2
i hope to setup a System blue as soon as i can get one - but i have a not so trivial question.
- how much bandwith will be used?
- how much data will be send /received (estimate) per month?
Tank you in advance
Greetings
Bjoern
The station will be installed in the area of Koblenz / Rhineland-Palatinate / Germany.
Threads: 12
(2016-08-29, 14:40)Karlchen_1 Wrote: Hi,
Tank you in advance
Greetings
Bjoern
Hi Bjoern,
I have a System Red in the U.S. On some active days here, I've sent over 1 GB/ day. Fortunately, it doesn't happen often, but it does happen. System Blue should be about the same, possibly a little more efficient, because of the new compression ratios built into it.
Hope this helps,
John
Threads: 62
(2016-08-29, 14:58)John.Sacrey Wrote: (2016-08-29, 14:40)Karlchen_1 Wrote: Hi,
Tank you in advance
Greetings
Bjoern
Hi Bjoern,
Hope this helps,
John
In the last 14 hours, 1439 has sent <80 MB , approximately 108,000 signals.... typical packet is approx. 760 bytes
