#81
(2019-06-26, 03:24)bwreed Wrote: User Name: BWREED
Station Number: 2515
Region... North America
User ID: 1939.  All station info is correct.  Anony = N.  Station does show on LightningMaps.org but not on Blitzortung.  Station details on LightningMaps does not show station as active though it is recording strikes and sending the good ones.  TIA
Brad
I can find you as a station operator on Lightninmaps, as 2526/19*39 ..but cannot find you as a station.  I also cannot receive any signals from 2515 on the Sferics.,US signals page... which means 2515 does not exist on the BLITZORTUNG station database...  examine this:
On your Blitzortung station operator's page, station setup, make sure you've entered the correct  device ID... check against your controller GUI status page:
[Image: 25151.jpg]
[Image: 25152.jpg]
IF the DEVICE IDs match,(no dashes) and"N" is entered,do nothing..this is an issue for EGON.
If it doesn't match your operator's page (no dashes)
then that's probably the reason, --The server isn't recognizing you.
(gui will show dashes ,Station Config page no dashes)
IF That's the case, you need to delete the improper station...
Scroll down a bit... check delete and save
[Image: 25153.jpg]
Then scroll back to the top, and register a new station  device, and save... you'll probably get  a new station number, also...
[Image: 25154.jpg]
The ONLY Wyoming station I can find listed is  2526, Cheyenne.
Brad
[Image: 25151.jpg]
[Image: 25152.jpg]
[Image: 25153.jpg]
[Image: 25154.jpg]
Thanks Mike.  The Device and Processor IDs MATCH.  When I login on LightningMaps and pull up my station info it displays:
Here you can find statistics of the TOA lightning detection station Hulett.
  • Id: 2515
  • Firmware: 0.0
  • Controller: 19.5
  • Amplifier: H1 / E1
  • Antenna 1: Loop, diameter=707mm, windings=4
  • Antenna 4: Electric field, length=50mm
  • Comment: Testing
General statistics of the last hour
  • Station active: no
  • Last active: 12.6 minutes ago
  • Last update: 12.6 minutes ago
  • Last detected stroke: None
  • Last signal: -
So they think the station exists and the info is correct.  However, the station does not list on LightningMaps nor on BO.  My guess is it's an EGON problem to solve.  Do I need to do anything to make him aware???
Thanks again for your help.
Brad
Brad...
Check your email for update..
I am sorry, but I am not receiving any signals from Station 2015 on the server for Region 3. As long as no signals have been received, the station will not be displayed either as active nor as inactive.
I would connect the station for testing to another network, perhaps the UDP package on port 8307 does not come through.
Stations: 2656, 3044
(2019-06-27, 16:23)Egon Wrote: I am sorry, but I am not receiving any signals from Station 2015 on the server for Region 3. As long as no signals have been received, the station will not be displayed either as active nor as inactive.
Don't know if it is a typo but the station is 2515 not 2015.  Brad
user name = stevecollier
station number = 2302
region = North America
station continually flips as active between old location "Rockaway" and current location "Oakland." Same signals shown on both station statistics page. Station shows up on blitzortung.org but not lightningmaps.org.
User Name: photinos
Station Number: 2556.
Region: North America
Station 2556
Stations: 2297, 2556
(2019-07-14, 17:23)photinos Wrote: User Name: photinos
Upgraded
user name = geofabryka
station number = 2557
region = Europe
Thank you
Username:  vedrin
Station id: 2497
Region: Europe
Thanks!
Station: 2497
Stations: 2497
User Name: brinkg
Station Number: 2563 and 2583 (2583 Just appeared a over the weekend)
Region: Server - Hungary
Country is South Africa
Station was only showing up on Vector Map, not anymore
Station does not show up in station List.
After Reboot, System blue shows Station 0 on landing page
Regards
Brink
User Name for Forum: dgoeldi
Station Number: 2597
Region 3
I have inserted a search funktion on the vector map. If you dont find your station on the map, try
http://map.blitzortung.org
-> Extended user interface
-> enter the station number
You will also get a reason, if the station is not on the map.
The station list of blitzortung.org still has some minor bugs concerning the assignment of regions that I will fix next.
(2019-07-23, 16:09)vedrin Wrote: Username:  vedrin
Station id: 2497
Region: Europe
Thanks!
I would be grateful if my group membership could be upgraded from "Registered forum member" to "Participant". Thanks!
Station: 2497
Stations: 2497
User Name for Forum: cowdoclance
Station Number: 2595
User: 1857
User name: Szutek
Station: Jelenia Góra/Poland
Operator status not updated.
Thank You.
Stations: 2629
STATION NOT LISTED
USER: 2044
STATION NUMBER : 2644
EUROPE / GREECE
LISTED NOW.. DISCARD THIS MSG
User: 1878
User name: ustlab
Station: 2630
Not listed on lightningmaps.org
Stations:2630
user = 1896
user name = old_dutch
station number = 2588
region = Asia Japan
no statistics while clicking station number link and missing region : Oceania
Jack
Station: 2588
The statistics on Lightningmaps.org currently only include stations that send data to Europe, Oceania or North America. I also entered Station 2588 for Oceania, but the statistics still do not seem to work. Please ask Tobias for help.
  Station List not showing any United Kingdom stations dgoadby 2 13,203 2019-04-15, 16:35
Last Post: dgoadby
  Removing Station 723 from list Ian.Cooke 5 29,869 2015-02-03, 20:39
Last Post: Toxic
