Lightning maps lacking road data
I used the http://www.lightningmaps.org/realtime?lang=en website for the first time this evening and it works very well.
I have one comment, though. When you zoom in, the Google Maps API doesn't display roads, only railroads. This makes interpretation in rural areas difficult, since towns are often spaced widely apart. Also here in the US we are used to seeing things against an overlay of road networks. If this can be fixed or enabled as an option, it would help a lot.
Thanks,
Tim
Did you try the sattelite option?
Usually the roads can be seen then.
Stations: 1209
Roads have been disabled, because sometimes it looks too confusing in combination with the stroke markers. However, we've now enabled the roads for the normal map. In a future version, we will provide an additional option to toggle the roads individually (already on the to-do list).
  computed lightning data documentation theperk 0 248 2024-03-25, 07:58
Last Post: theperk
  Lightning Data Access GHinchey 6 28,275 2021-05-18, 16:04
  No lightning data (Europe) Noodweer Benelux 2 13,543 2017-08-12, 10:34
