Efficiency
#38
"Efficiency" is used on LMO.  The difference in terms can be either significant, or similar...
"Efficiency"  ... as in "Skillful use of energy or industry to accomplish desired results with little waste of effort
Station X sends 200 signals
Station Y sends 150 signals
BUT  X is less "efficient" than station Y which sends fewer signals.
That is, both stations send good info about 100 strokes, X should have the same "Effectivity" as "Y"  but certainly less "efficiency".
