#16
(2016-08-10, 12:11)bazzalight Wrote:
(2016-05-31, 21:30)RichoAnd Wrote: Richo,
I have started making the H field Copper tube Loop antenna shown in your mini guide and also from http://users.skynet.be/DanielV37/Project...m#Hardware.  I have produced 3D print files for the top & bottom Junctions from the drawings on that site and have published these files at http://www.thingiverse.com/thing:1713141 .  I have included attribution to the design as best I could find reference.  Can you have a quick look at this url and advise if any further attribution is needed.
thanks
Barry (Australia)
Have a lot of suggestions for changes - water intrusion is a challenge
By the way - time has run from this antenna - it is too large, and intended for System GREEN
Make it of brake tube 5-6 mm and a diameter of ~ 40cm
Most effective is the "Möbius" with transformer
RE: Antennas for System BLUE - Mini Guide - by RichoAnd - 2016-08-11, 06:31
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 50,840 2025-04-19, 23:25
Last Post: DrFX
  Blue Mini Marcel_1 1 8,667 2025-04-01, 19:15
Last Post: Marcel_1
  Metal housing for System Blue Mini blt 10 30,129 2025-03-09, 08:27
Last Post: DrFX
  mini blue icpass 1 13,257 2024-09-02, 05:14
Last Post: gerbold
  Any benefit to running a red and mini blue systems together Broms 2 12,267 2024-08-22, 15:44
Last Post: Broms
