System blue problem
(2017-01-06, 13:37)Tobi Wrote:
(2016-11-29, 05:00)ohifra Wrote: You need to Save to Flash and Reboot to take effect some of the new settings!
If I click on save button and reboot,  the system has the same message.
That's strange. Is this still the case? Can you reproduce it?
(2016-11-29, 05:00)ohifra Wrote: Another problem is that the System blue often emits a long beep and the LAN LED disappears.
Unfortunately this is currently a common issue. Try to enable "Hide Hardfaults" under System menu.
Good morning, I solved the problem by connecting the detector with a LAN cable category 7 and after I set the LAN port in full duplex.
Stations: 1583
System blue problem - by ohifra - 2016-11-29, 05:00
RE: System blue problem - by Tobi - 2017-01-06, 13:37
RE: System blue problem - by ohifra - 2017-02-08, 04:33
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 50,815 2025-04-19, 23:25
Last Post: DrFX
Lightbulb Fixed: Problem with System Green & Windows Tracker MuellerJ 1 21,249 2016-09-22, 19:03
Last Post: MuellerJ
