(2017-08-08, 19:58)pasense Wrote: You should consider to use the low pass filters. With them I could cut out the high frequency noise and could concentrate on hunting the noise sources around 10-30 kHz. Soldering the tiny filters in was far easier than I feared, but they are of course a bit expensive.
I am seriously considering buying those filters. I read in the instructions manual that they are enabled in software by soldering closed a jumper. I'm very curious what options appear in the web interface when you do this. Is it possible to adjust the frequency manually, and what are the limits??
Thanks!
RE: Identifying interference with oscilloscopes and software-defined radio - by djhuft - 2017-08-10, 00:21
  interference with Ham Radio. Ok8leo 5 27,292 2025-08-26, 09:50
Last Post: Ok8leo
  Possibility of contributing to a second-tier experimenta hardware / software effort? louloulou 0 12,946 2020-08-16, 19:04
Last Post: louloulou
  Identifying which controller I'm looking at Dale.Reid 3 31,289 2016-06-20, 14:19
  NeB Q: Will nearby FM Radio Cell towers cause problems br1ght 2 27,619 2015-09-18, 20:53
Last Post: br1ght
  Gain settings by software? PA4EME 4 44,582 2014-09-07, 21:14
