#19
(2017-09-07, 02:58)readbueno Wrote: I was only running for a short while, but, as you can see, very little has changed.
It does seem that the E channel is not going negative and the other two are just generating garbage interference.
Hi Brian,
The repetitive pattern on those 3 graphs almost looks like a bad switching power supply. Could the PS have damaged the controller, or vice versa? It's probably not, but I thought that I should mention it.
I power mine with theĀ  5VDC 2A charger that came with my Android tablet.
73, Mike
www.w0btu.com
RE: Problem after updating firmware. blue 8.32b - by mwaters - 2017-09-10, 19:50
  9.4 Blue 19.3 Board Can't update firmware ni5f 6 19,549 2025-03-11, 13:53
Last Post: ni5f
  Firmware 10 on System Red PCB 10.5 - firmware bug ??? mmlightning 1 13,678 2025-02-27, 08:37
  System Blue GPS problem Steve- 12 85,693 2016-11-15, 09:35
Last Post: DnH2016
