Several questions about the circuit protection that using linear power supplies
My two cents, probably worth less.
If anything more than a quick blow fuse significantly increased safety then I'd expect to see that in ordinary commercial designs.
A small transformer is going to saturate so what goes in will be limited at the output.
Switching/fusing the neutral is a very bad idea unless it's a mechanically linked double pole swich. The thing will look dead but isn't.
The fuse needs to after the switch not before. So you can switch off and you are not changing a live fuse.
How do you know that the diodes aren't zapped open circuit after a surge?
RE: Several questions about the circuit protection that using linear power supplies - by allsorts - 2017-12-22, 23:03
  Linear power supply JupiterJoe 25 168,688 2022-03-01, 02:22
Last Post: hazelnut
  System RED circuit and PCB diagram Mark.Smith 2 26,590 2018-02-03, 15:59
Last Post: Mark.Smith
  System Blue Circuit Diagrams nerd65 0 16,424 2016-06-22, 13:56
Last Post: nerd65
  Circuit diagram+parts list for amplifier V5.5 UweBergh 5 68,934 2015-02-04, 00:48
Last Post: UweBergh
