(2018-06-13, 22:16)vk2him Wrote:
(2018-06-13, 19:57)Tobi Wrote: Since Sunday the live map is using Leaflet API with OpenStreetMap as main map. Rewriting took longer than expected, but everything behaves (almost) as before.
Hi Tobi - I like the new look however the way the station circles are now drawn makes it very hard to tell when they light up green when zoomed out as you're infilling the green circle with the same shade of green .. it's easy to see however when they light up Purple. Is there any way you can change the colour of the green infill to make visibility better?
Thanks
Ian
Ian, does yours not look like mine below? Perhaps you need to adjust the LMO display settings.
RE: LightningMaps.org: Real-time Lightning Map - by mwaters - 2018-06-13, 22:36
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 13,821 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 18,659 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 25,296 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 23,288 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 16,216 2024-07-01, 07:29
Last Post: Blubbel
