(2018-06-13, 22:36)mwaters Wrote:
(2018-06-13, 22:16)vk2him Wrote:
(2018-06-13, 19:57)Tobi Wrote: Since Sunday the live map is using Leaflet API with OpenStreetMap as main map. Rewriting took longer than expected, but everything behaves (almost) as before.
Hi Tobi - I like the new look however the way the station circles are now drawn makes it very hard to tell when they light up green when zoomed out as you're infilling the green circle with the same shade of green .. it's easy to see however when they light up Purple. Is there any way you can change the colour of the green infill to make visibility better?
Thanks
Ian
Ian, does yours not look like mine below? Perhaps you need to adjust the LMO display settings.
Hi Mike, Yes mine looks like yours but note you have zoomed in to level 5 which makes it easier to see the green highlighted stations. I normally use zoom level 4 as Australia has fewer stations.
Stations: 2039
RE: LightningMaps.org: Real-time Lightning Map - by vk2him - 2018-06-13, 23:21
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 14,217 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 19,022 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 25,982 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 23,895 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 16,547 2024-07-01, 07:29
Last Post: Blubbel
