Account Setup
Mike-
The problem is that you have enabled "Need Authentication" under Web Interface in the settings tab and you are viewing the Status page as a guest - in other words you have not logged in to your controller yet so most stuff is hidden including the Device ID numbers you need.
To make this work, you need to press the Login link and then login using the username and password you created initially. Once you're logged in you will be able to view the Device ID numbers you need. Unless you specifically want to user that login facility, you can disable the "Need Authentication" . Most of us don't have it enabled as we don't have our controller's status page exposed to the internet using port forwarding.
Hope that helps. Cheers
Stations: 2039
Account Setup - by Mike - 2018-12-03, 22:50
RE: Account Setup - by dupreezd - 2018-12-03, 22:59
RE: Account Setup - by Mike - 2018-12-03, 23:04
RE: Account Setup - by dupreezd - 2018-12-03, 23:06
RE: Account Setup - by Mike - 2018-12-03, 23:25
RE: Account Setup - by dupreezd - 2018-12-03, 23:31
RE: Account Setup - by mwaters - 2018-12-03, 23:35
RE: Account Setup - by mwaters - 2018-12-04, 00:10
RE: Account Setup - by Mike - 2018-12-04, 01:54
RE: Account Setup - by dupreezd - 2018-12-04, 02:01
RE: Account Setup - by Mike - 2018-12-04, 02:49
RE: Account Setup - by dupreezd - 2018-12-04, 02:52
RE: Account Setup - by dupreezd - 2018-12-04, 02:55
RE: Account Setup - by vk2him - 2018-12-04, 06:13
RE: Account Setup - by Mike - 2018-12-04, 07:45
RE: Account Setup - by Mike - 2018-12-04, 14:41
RE: Account Setup - by Mike - 2018-12-04, 15:11
RE: Account Setup - by cutty - 2018-12-04, 17:22
RE: Account Setup - by cutty - 2018-12-04, 17:45
RE: Account Setup - by Mike - 2018-12-05, 02:05
RE: Account Setup - by Mike - 2018-12-05, 03:59
RE: Account Setup - by vk2him - 2018-12-05, 04:33
RE: Account Setup - by Mike - 2018-12-07, 17:56
RE: Account Setup - by dupreezd - 2018-12-07, 18:43
RE: Account Setup - by Mike - 2018-12-07, 21:02
RE: Account Setup - by cutty - 2018-12-07, 21:16
RE: Account Setup - by mwaters - 2018-12-07, 21:17
RE: Account Setup - by Mike - 2018-12-07, 21:21
  Antenna setup. josecmorales 1 16,770 2021-07-19, 16:23
  My E-field antenna setup TomVal 3 26,908 2020-11-05, 15:48
Smile System blue antena setup site. bartasmosina 7 51,327 2019-05-10, 15:06
Last Post: mwaters
