LightningMaps.org: Real-time Lightning Map
#80
(2014-07-14, 23:31)Cutty Wrote: A beep does not mean a valid, or a usable 'stroke'. It beeps on any signal, noise, car, pet fence, switch, etc that causes a trigger.... If you're not seeing signals on the Participants page, or low values, or not seeing them on the map, it could mean that most of your signals are noise.
1028 Florø Norway Running 2014-07-15 01:31 257 0 | 0% 0 | 0% 26 | 3%
I know that there is some noise, and I had it worse earlier.
But lately it seems to be a lot of good signals, according to waveform, and the status page :
SignalsReceived: 36255, Good: 31529, Sent: 31511
Signal RateLast second: 0, Last 60s: 0.7
as of :
RTC time2014-07-15 17:05:38
Running for13h, 5m
I also see that I get "credit" for almost every strike closer to home, but more rarely when there is a bigger distance.
Of course, this is also dependent on signal strength, and with more distance, the weaker the signals will be.
Ill make a video to show what I mean, and put it on Youtube...
Regards, Asbjorn
Stations: 1028
Messages In This Thread
RE: Real time Lightning Map - by RichoAnd - 2014-05-09, 18:32
RE: Real time Lightning Map - by cutty - 2014-05-09, 19:59
RE: Real time Lightning Map - by scilover - 2020-06-03, 10:54
RE: Real time Lightning Map - by Dale.Reid - 2014-05-09, 20:55
RE: Real time Lightning Map - by Tobi - 2014-05-09, 21:12
RE: Real-time Lightning Map - by cutty - 2014-05-09, 22:16
RE: Real-time Lightning Map - by John.Sacrey - 2014-05-09, 23:56
RE: Real-time Lightning Map - by Tobi - 2014-05-10, 16:21
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 00:46
RE: Real-time Lightning Map - by cutty - 2014-05-11, 01:21
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 03:22
RE: Real-time Lightning Map - by robo - 2014-05-11, 12:11
RE: Real-time Lightning Map - by aib - 2014-05-11, 12:24
RE: Real-time Lightning Map - by cutty - 2018-12-16, 17:05
RE: Real-time Lightning Map - by Tobi - 2014-05-11, 17:32
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-11, 18:54
RE: Real-time Lightning Map - by Tobi - 2014-05-11, 19:47
RE: Real-time Lightning Map - by weatherc - 2014-05-12, 09:36
RE: Real-time Lightning Map - by Tobi - 2014-05-15, 20:50
RE: Real-time Lightning Map - by weatherc - 2014-05-15, 21:21
RE: Real-time Lightning Map - by Tobi - 2014-05-16, 17:54
RE: Real-time Lightning Map - by Dale.Reid - 2014-05-17, 00:15
RE: Real-time Lightning Map - by saschaa - 2014-05-18, 18:42
RE: Real-time Lightning Map - by DelandeC - 2014-05-20, 17:22
RE: Real-time Lightning Map - by Tobi - 2014-05-20, 21:18
RE: Real-time Lightning Map - by DelandeC - 2014-05-21, 09:07
RE: Real-time Lightning Map - by steelek - 2014-05-24, 15:48
RE: Real-time Lightning Map - by cutty - 2014-05-24, 15:50
RE: Real-time Lightning Map - by HamelGre - 2014-05-30, 12:36
RE: Real-time Lightning Map - by Tobi - 2014-05-30, 17:22
RE: Real-time Lightning Map - by HamelGre - 2014-05-30, 19:58
RE: Real-time Lightning Map - by cutty - 2014-05-30, 21:34
RE: Real-time Lightning Map - by Tobi - 2014-05-31, 06:37
RE: Real-time Lightning Map - by HamelGre - 2014-05-31, 11:19
RE: Real-time Lightning Map - by zalama - 2014-06-07, 13:04
RE: Real-time Lightning Map - by mabro - 2014-06-07, 13:39
RE: Real-time Lightning Map - by Knickohr - 2014-06-07, 14:09
RE: Real-time Lightning Map - by Tobi - 2014-06-07, 14:51
RE: Real-time Lightning Map - by zalama - 2014-06-08, 05:29
Real-time Lightning Map - by NosDE - 2014-06-09, 20:08
RE: Real-time Lightning Map - by Tobi - 2014-06-10, 10:14
RE: Real-time Lightning Map - by weatherc - 2014-06-10, 12:29
Real-time Lightning Map - by NosDE - 2014-06-10, 10:39
Real-time Lightning Map - by NosDE - 2014-06-10, 12:40
RE: Real-time Lightning Map - by Tobi - 2014-06-10, 18:17
RE: Real-time Lightning Map - by weatherc - 2014-06-11, 14:22
RE: Real-time Lightning Map - by Tobi - 2014-06-11, 18:19
Real-time Lightning Map - by NosDE - 2014-06-11, 19:29
RE: Real-time Lightning Map - by Tobi - 2014-06-11, 19:51
Real-time Lightning Map - by NosDE - 2014-06-11, 21:45
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:29
RE: Real-time Lightning Map - by cutty - 2014-06-14, 21:39
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:45
RE: Real-time Lightning Map - by Tobi - 2014-06-14, 21:53
RE: Real-time Lightning Map - by W3DRM - 2014-06-14, 21:59
Real-time Lightning Map - by NosDE - 2014-06-14, 22:02
RE: Real-time Lightning Map - by Tobi - 2014-06-20, 15:44
RE: Real-time Lightning Map - by AleT - 2014-07-25, 13:27
RE: Real-time Lightning Map - by HamelGre - 2014-06-21, 13:10
RE: Real-time Lightning Map - by Tobi - 2014-06-21, 13:45
RE: Real-time Lightning Map - by ecreif - 2014-06-23, 14:56
RE: Real-time Lightning Map - by wxrman - 2014-06-26, 00:50
RE: Real-time Lightning Map - by jade - 2014-06-26, 04:21
RE: Real-time Lightning Map - by jumpjack - 2014-06-26, 12:25
RE: Real-time Lightning Map - by Tobi - 2014-06-26, 17:57
RE: Real-time Lightning Map - by cutty - 2014-06-26, 18:17
RE: Real-time Lightning Map - by weatherc - 2014-07-13, 13:43
RE: Real-time Lightning Map - by Tobi - 2014-07-13, 15:25
RE: Real-time Lightning Map - by Knickohr - 2014-07-13, 15:50
RE: Real-time Lightning Map - by Tobi - 2014-07-13, 17:47
RE: Real-time Lightning Map - by Knickohr - 2014-07-13, 17:53
RE: Real-time Lightning Map - by HolzHaus - 2014-07-14, 23:29
RE: Real-time Lightning Map - by Tobi - 2014-07-16, 10:47
RE: Real-time Lightning Map - by HolzHaus - 2014-07-16, 11:24
RE: Real-time Lightning Map - by cutty - 2014-07-14, 23:31
RE: Real-time Lightning Map - by Asbjorn.Aamot - 2014-07-15, 17:19
RE: Real-time Lightning Map - by Tobi - 2014-07-16, 18:22
RE: Real-time Lightning Map - by ari.jasberg - 2014-07-19, 14:54
R: RE: Real-time Lightning Map - by jumpjack - 2014-07-20, 08:20
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 13,003 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 17,963 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 23,890 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 22,074 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 15,722 2024-07-01, 07:29
Last Post: Blubbel
Users browsing this thread: 11 Guest(s)
