shield the E-field ?
Hi to you all
 I wonder is it possible to shield the E-field
Because I see it  receive many noise   really   many  !!!!!!!!!!!!!!
I have test it
Test 60min
Test 1  only the shield ferrite 18:45 – 19:45   =    signals = 3052   M=48.2%  L=20.9%
Test 2  ferrite shield  + 90cm loop =  signals = 5670   M=20.7%  L=33.5%
Test 3 E-field ( 20cm ) signals = 32854   M=11.1%  L=9.1%   very high !!!!!!
Here below the graphic
You see the green line  this is ok   but the rest is to noisy
So is it possible to shield the E-field  ??
Greetings   Gert
[Image: graphic.jpg]
Stations: 127, 1845, 3108
  Shield the E-probe? Max_Headroom 12 90,539 2017-11-01, 18:01
Last Post: KY5G
