Shielding antennas
(2015-01-11, 19:07)Andrew.Instone-Cowie Wrote:
(2015-01-11, 17:37)Cutty Wrote: There should be no issue with the Controller, or even the E amplifier being in
the computer room, if all else is good. There can be issues with H amplifier and antennas in the same room.
Can you clarify that last sentence? There can be issues with exactly which components being in the same room? Thanks.
Andrew
The H Field AMP should be connected with shortest possible wire length, right to the loops. You do not want them near computers etc.
The E field probe/Preamp assy is outside, up in the air, far from structures and noise sources. The E probe/preamp assy then connects with coax to the
E field amplifier, which can be right next to the controller, which could be in the same room with computers, etc, if everything is otherwise ok....
All of the above discussions are generally laid out in the forum discussions and in the 'project description' and construction pdf http://www.blitzortung.org/Webpages/inde...=en&page=3
Shielding antennas - by orion_jb2001 - 2015-01-11, 14:39
RE: Shielding antennas - by cutty - 2015-01-11, 15:12
RE: Shielding antennas - by orion_jb2001 - 2015-01-11, 15:35
RE: Shielding antennas - by cutty - 2015-01-11, 17:37
RE: Shielding antennas - by orion_jb2001 - 2015-01-11, 18:33
RE: Shielding antennas - by cutty - 2015-01-11, 23:57
  Shielding Alanpenwith 1 11,455 2017-10-22, 10:36
Last Post: readbueno
Photo H field ferrite shielding orion_jb2001 5 31,828 2015-01-30, 03:58
Last Post: orion_jb2001
  Ferrite Rod Antenna Shielding Dave.Auld 4 31,624 2014-08-18, 08:58
Last Post: Dave.Auld
