Efficiency
#35
Some quick thoughts:
Hence, perhaps,  one reason the 'interference mode' paradigm at the controller, especially for 'nearby' storms.
They contribute to many of my 'signals', outside of my normal local 'junk', which I struggle mightily to minimize. Last year, another operator  and I compared signals in real time, over an extended time, and, certain signals, were easily recognizable as same 'sferic', but were classed as 'junk'... yet we observationally concluded they were the same signal, not local, and were sferics, of some type. No, Dave and I do not have documentation concering those observations... but we solved an interesting 'anomaly' that puzzled us both at the time.
Another factor is the longer delayed  'skywave' components.. (e.g.: 4+ reflection) many of which are 'rejected by the server because of the delay, or distortion being too far out of sync with the 'detecting' time stamp.. yet they are the same stroke, but classed as 'noise',... this is resolved by 'reduced gain' and range locally, obviously.  Which, I think, is part of the reason for Egon's paradigms... in general, to 'push' the majority of stations in the 'center' of a region into a more efficient, let us say, <1500 km range.  While at the same time encouraging 'edge' regional stations to support 'less dense' regions, with higher gains, etc.  Those 'edge' stations would necessarialy have longer range, more signals, perhaps a significantly lower 'effectivity'... in order to help support network development.
For network efficiency, as opposed to station effectivity, it is not necessary for me, in a dense region, being in the center, to detect signals >1500 km... other stations handle that... if I'm sending only skywaves from those signals, and they are way beyond the 'time frame' for locating, distorted, delayed, then that, for network, is "junk".  Matter of fact, for network efficiency, I'd be better off to reduce to <800 km, and stop sending my extraneous signals, of no locating or detecting use.  But the computation then implies that 689 is a very 'ineffective' station.
Now, the above thoughts concern true 'atmospheric' reception.  They don't apply to local noise, etc, which we also may put too much emphasis.  Some of us, like I, have to simply live with a higher 'signal' count many times, therefore 'less effectivity', in order to actually provide meaningful network usable signals.  But if I failed to mitigate as much as possible my transmission of the junk, than that's my fault.  If I can't mitigate the junk, than I must make my station as efficient, as effective, as possible, and this may mean the "3rd column" long range 'does not apply to me', and pay more attention to my own 'localized' data, and operating restrictions....
