Launch of System Blue delayed
#67
(2016-01-14, 00:41)kevinmcc Wrote: ...
What about adding MOD-1016v8 lightning detector?
Experimental add in of the AS3935  you are referring to was done by several members with System RED. Results are / were mixed. Most of us didn't bother fooling with it. Search this forum for "AS3935", most postings are likely in the 'internal' boards for operators only.
You can also find discussions at http://www.wxforum.net/index.php?board=115.0
Search for 'AS3935'
The firmware for RED controller does include support for AS3935, but whether that will be carried over into BLUE, or retained in RED updates is possibly still a matter under consideration.
Note that one issue with the network is quality of data and standardization of systems, so early experimentation or add ons to BLUE are likely to be discouraged to some extent.
Also note that the AS3935 contributes NO data or info to the Blitzortung network...
Launch of System Blue delayed - by Egon - 2015-07-07, 15:08
RE: Launch of System Blue delayed - by Bonzo - 2015-07-07, 16:44
RE: Launch of System Blue delayed - by ace2 - 2015-07-08, 12:27
RE: Launch of System Blue delayed - by Tobi - 2015-07-09, 11:14
Liebe ist blau - by cutty - 2015-07-11, 12:41
RE: Launch of System Blue delayed - by cutty - 2015-07-12, 12:25
RE: Launch of System Blue delayed - by robo - 2015-07-11, 16:58
RE: Launch of System Blue delayed - by Tobi - 2015-07-12, 15:05
RE: Launch of System Blue delayed - by Tobi - 2015-07-12, 21:51
RE: Launch of System Blue delayed - by WB2RHM - 2015-07-13, 17:02
RE: Launch of System Blue delayed - by Donar - 2015-07-19, 08:05
RE: Launch of System Blue delayed - by Tobi - 2015-07-19, 08:30
RE: Launch of System Blue delayed - by Donar - 2015-07-19, 14:59
RE: Launch of System Blue delayed - by W3DRM - 2015-09-01, 18:44
RE: Launch of System Blue delayed - by G3WGV - 2015-09-14, 16:35
RE: Launch of System Blue delayed - by Tobi - 2015-09-14, 20:18
RE: Launch of System Blue delayed - by G3WGV - 2015-09-14, 17:59
RE: Launch of System Blue delayed - by Tobi - 2015-09-17, 17:49
RE: Launch of System Blue delayed - by Bonzo - 2015-10-05, 16:16
RE: Launch of System Blue delayed - by zalama - 2015-10-08, 14:55
RE: Launch of System Blue delayed - by Bonzo - 2015-10-09, 16:10
RE: Launch of System Blue delayed - by cutty - 2015-10-10, 00:36
RE: Launch of System Blue delayed - by cutty - 2015-10-10, 02:32
RE: Launch of System Blue delayed - by davmoo - 2015-11-09, 09:03
RE: Launch of System Blue delayed - by W3DRM - 2015-11-10, 01:51
RE: Launch of System Blue delayed - by davmoo - 2015-11-11, 06:27
RE: Launch of System Blue delayed - by W3DRM - 2015-11-11, 16:47
RE: Launch of System Blue delayed - by cutty - 2016-01-14, 14:21
RE: Launch of System Blue delayed - by Tobi - 2016-01-14, 13:53
RE: Launch of System Blue delayed - by cutty - 2016-01-14, 15:05
RE: Launch of System Blue delayed - by W3DRM - 2016-01-14, 21:54
RE: Launch of System Blue delayed - by Tobi - 2016-03-01, 13:43
RE: Launch of System Blue delayed - by Bonzo - 2016-03-01, 19:02
RE: Launch of System Blue delayed - by cutty - 2016-03-01, 19:55
RE: Launch of System Blue delayed - by Bonzo - 2016-03-01, 21:53
RE: Launch of System Blue delayed - by cutty - 2016-03-01, 22:16
RE: Launch of System Blue delayed - by Bonzo - 2016-03-02, 01:32
