Blitzortung and Photography
#33
Here`s some tips! just make sure to set your lens to manual focus, it’ll give more control. Then, set camera ISO to the lowest. Your shutter speed should be longer as well to capture the lightning. As for your aperture, start out with an aperture of f/5.6. You can also use a lightning trigger, it’ll be easier to take the photograph. You can check out Nikon’s article on it  https://www.nikonusa.com/en/learn-and-ex...tning.html
Blitzortung and Photography - by psper - 2016-05-18, 14:37
RE: Blitzortung and Photography - by psper - 2016-05-18, 20:37
RE: Blitzortung and Photography - by chubros - 2016-05-18, 18:47
RE: Blitzortung and Photography - by psper - 2016-05-18, 20:36
RE: Blitzortung and Photography - by psper - 2016-05-19, 00:00
RE: Blitzortung and Photography - by cutty - 2016-05-30, 20:31
RE: Blitzortung and Photography - by psper - 2016-05-30, 21:42
RE: Blitzortung and Photography - by rodalco - 2016-05-23, 05:29
RE: Blitzortung and Photography - by psper - 2016-05-29, 15:42
RE: Blitzortung and Photography - by robo - 2016-05-29, 15:57
RE: Blitzortung and Photography - by Tobi - 2016-05-30, 15:25
RE: Blitzortung and Photography - by robo - 2016-05-30, 16:37
RE: Blitzortung and Photography - by chubros - 2016-05-31, 09:18
RE: Blitzortung and Photography - by psper - 2016-05-30, 16:51
RE: Blitzortung and Photography - by psper - 2016-05-30, 16:54
RE: Blitzortung and Photography - by robo - 2016-05-30, 16:58
RE: Blitzortung and Photography - by Tobi - 2016-05-31, 19:51
RE: Blitzortung and Photography - by chubros - 2016-05-31, 20:07
RE: Blitzortung and Photography - by piepants - 2016-09-05, 11:07
RE: Blitzortung and Photography - by kevinmcc - 2016-09-05, 15:16
RE: Blitzortung and Photography - by piepants - 2016-10-10, 11:41
RE: Blitzortung and Photography - by cc1309 - 2016-10-13, 13:05
RE: Blitzortung and Photography - by piepants - 2016-11-08, 10:19
RE: Blitzortung and Photography - by chubros - 2016-12-12, 20:23
RE: Blitzortung and Photography - by piepants - 2017-02-18, 03:03
RE: Blitzortung and Photography - by Mike6158 - 2017-03-30, 03:04
RE: Blitzortung and Photography - by chubros - 2018-06-12, 09:37
RE: Blitzortung and Photography - by scilover - 2020-06-05, 11:11
