Blue H field Ferrite antenna in L or Delta shape?
I started with all three loops together but local conditions mean that 90 degrees between the loops produces useless signals. See post #5 ... I now have seperate vertical loops with a horizontal around one of them.
Starting seperate means you don't have to rebuild if you need to use the null of a loop to reduce local interfernce. If you have the loops fixed at 90 degrees, you can null the interference on one but the other is then aligned for maximum pick up...
RE: Blue H field Ferrite antenna in L or Delta shape? - by allsorts - 2017-03-30, 00:57
  Blue e-field antenna question llowrey 2 7,415 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 12,033 2020-11-05, 15:48
  blue ferrite / loop antenna connection? MTO-Mareuil 1 6,782 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 47,173 2020-06-03, 12:16
Last Post: GJ7DNI
  Can E-field antenna be casted in resin? OH4GRM 3 12,229 2020-06-01, 13:19
Last Post: dupreezd
