Station 1745 is online
I see in your image that you are using the 2A channel which is where the E-field is normally found using the smaller amplifier with the F-type connector end and 2 screw terminals. I would have expected you to be using the larger H-field amplifier with the 6 screw terminals and RJ45 connector for the ferrite rods connection.
Was this your intention? If so, then I'm not familiar with this setup.
I (and most others) have their loops connected to the larger amplifier in pins 1 & 2 and 4 & 5 for each loop. Those will show up in the controller on channels 1A (red) and 1B (green), once re-enabled.
WU: KROCKF4 || CWOP: C9861 || CoCoRaHS: MI-KN-83 || Blitzotung: 1737
Davis Vantage Pro2 Plus --> Meteohub
weather.huffman.info
Stations: 1737
Station 1745 is online - by Mike6158 - 2017-04-01, 19:27
Station 1745 is online - by cbhiii01 - 2017-04-01, 20:34
RE: Station 1745 is online - by Mike6158 - 2017-04-01, 20:56
Station 1745 is online - by cbhiii - 2017-04-01, 20:55
RE: Station 1745 is online - by Mike6158 - 2017-04-01, 21:02
RE: Station 1745 is online - by cbhiii - 2017-04-01, 21:09
RE: Station 1745 is online - by Mike6158 - 2017-04-02, 04:23
RE: Station 1745 is online - by kevinmcc - 2017-04-01, 21:51
RE: Station 1745 is online - by Mike6158 - 2017-04-02, 04:43
RE: Station 1745 is online - by cbhiii - 2017-04-02, 13:12
Station 1745 is online - by cbhiii - 2017-04-02, 12:47
RE: Station 1745 is online - by Mike6158 - 2017-04-02, 13:32
RE: Station 1745 is online - by cbhiii - 2017-04-02, 13:46
RE: Station 1745 is online - by tbaggett - 2017-04-02, 15:33
RE: Station 1745 is online - by Mike6158 - 2017-04-02, 15:45
  Station 1888 near Bear Creek NC Online Nekota 5 29,597 2017-07-09, 22:58
Last Post: allsorts
