Station 1745 is online
(2017-04-01, 21:09)cbhiii Wrote: I see in your image that you are using the 2A channel which is where the E-field is normally found using the smaller amplifier with the F-type connector end and 2 screw terminals. I would have expected you to be using the larger H-field amplifier with the 6 screw terminals and RJ45 connector for the ferrite rods connection.
Was this your intention? If so, then I'm not familiar with this setup.
I (and most others) have their loops connected to the larger amplifier in pins 1 & 2 and 4 & 5 for each loop. Those will show up in the controller on channels 1A (red) and 1B (green), once re-enabled.
I have no idea what I'm doing lol and it's showing.
I'm going to switch to the H-field amplifier. I've got significant weather in central TX, about 300 miles away, and no strikes recorded. Not even one.
Michael Lloyd  NE5U
Weimar, TX USA
Stations: 1745
Station 1745 is online - by Mike6158 - 2017-04-01, 19:27
Station 1745 is online - by cbhiii01 - 2017-04-01, 20:34
RE: Station 1745 is online - by Mike6158 - 2017-04-01, 20:56
Station 1745 is online - by cbhiii - 2017-04-01, 20:55
RE: Station 1745 is online - by Mike6158 - 2017-04-01, 21:02
RE: Station 1745 is online - by cbhiii - 2017-04-01, 21:09
RE: Station 1745 is online - by Mike6158 - 2017-04-02, 04:23
RE: Station 1745 is online - by kevinmcc - 2017-04-01, 21:51
RE: Station 1745 is online - by Mike6158 - 2017-04-02, 04:43
RE: Station 1745 is online - by cbhiii - 2017-04-02, 13:12
Station 1745 is online - by cbhiii - 2017-04-02, 12:47
RE: Station 1745 is online - by Mike6158 - 2017-04-02, 13:32
RE: Station 1745 is online - by cbhiii - 2017-04-02, 13:46
RE: Station 1745 is online - by tbaggett - 2017-04-02, 15:33
RE: Station 1745 is online - by Mike6158 - 2017-04-02, 15:45
  Station 1888 near Bear Creek NC Online Nekota 5 29,583 2017-07-09, 22:58
Last Post: allsorts
