PCB 21
(2017-06-04, 22:34)Cutty Wrote:
(2017-06-04, 20:56)MonkeeRench Wrote: If the improved voltage regulator PCB 21 is now necessary for System Blue, where does one obtain the PCB 21 board -- or does one need to build it from scratch?
It is NOT necessary for current systems.
PCB 21 was a 'piggyback' modification added to early  19.1 / 19.2 boards to improve current capabilities, and is not applicable to current systems.
Current production Controller 19.3 or higher does not require the modification.... If you have an unmodified 19.1 or 19.2 board you should refer to Internal Forum //forum.blitzortung.org/showthread.php?tid=1836
Thanks Cutty for clarifying the ongoing Blue documentation.
PCB 21 - by MonkeeRench - 2017-06-04, 20:56
RE: PCB 21 - by cutty - 2017-06-04, 22:34
RE: PCB 21 - by MonkeeRench - 2017-06-05, 16:52
RE: PCB 21 - by cutty - 2017-06-05, 17:50
