Interested in setting up a station - Questions
(2017-08-04, 19:56)opadavis Wrote:
(2017-08-04, 18:30)John.Sacrey Wrote:
(2017-08-04, 18:22)opadavis Wrote: I discovered that a PC needs to be on and processing continuously to keep the station running. People considering starting a station should be told this. Perhaps this is in the literature and I just missed it.
This is incorrect. The system is completely self-contained with its own webserver. My Red system is plugged directly into my router and does not have a computer connection at all. I access the web server via my computers' browser.
My Blue is connected through ethernet cable to router also. When I connect to the controller through its IP address and adjust some settings, I get lightning signal flashes on the front of controller panel. When I put computer to sleep or turn it off, the flashes stop. So I assumed that communication to Blitzortung servers had also stopped. So far my station has not sent many signals that were used; I need to focus on my antennas and location.
I would be happy if I did not need the computer on, John. Please tell me how.
Peter
Hi Peter,
Do you by chance have your PC and System Blue plugged into the same battery backup?  If so, is your PC connected to the Master Control outlet (APC in the U.S. is like this) and when you shut down your computer it turns off the entire battery backup? This could be the issue. If this isn't the issue, I'm not sure.
John
Station: 1387
Stations: 1387
RE: Interested in setting up a station - Questions - by John.Sacrey - 2017-08-04, 23:47
  Interested to buy and install a Blue System scpa359 6 3,244 2024-02-29, 09:24
Last Post: ibispasanda
  New Station Registration Questions KY5G 19 75,176 2017-11-01, 18:13
Last Post: KY5G
  Some questions for begin of station work hashemiyan 1 11,566 2016-05-16, 13:59
Last Post: DelandeC
  Setting up a new station and Data Usage questions Avery 3 20,381 2016-05-02, 00:26
Last Post: dalek
  Interested in setting up a station in northern Norway Drayton 5 31,412 2014-09-06, 10:47
Last Post: ts20
