I recorded a bit more since last post. Keep in mind that you are seeing the spectrum between DC and 120 kHz.
10 hours of recording through the night:
[Image: WlwUPTI.png]
Another 10 hours from the daytime:
[Image: pNlYHpB.png]
There are lots of interesting signals here, in my opinion:
  • Both images: There is broadband interference across the spectrum periodically.
  • Both images: There is a signal that sometimes appears and drifts slowly from low 60 kHz range to steady-state above 70 kHz. Maybe this is some sort of thermal effect inside the interfering device?
  • Both images: The signals at 25 and 60 kHz are very strong and still present all the time.
  • Both images: There is a strong signal at 45 kHz that comes and goes.
  • Second image: There is a broadband interferer between 8 and 15 kHz that occasionally appears.
I'm not sure what to conclude...
The next time I am away from the apartment, I plan to shut off every circuit breaker, except for the one powering my laptop and Blitzortung receiver. Maybe some of these strange signals will disappear. If not, I probably need to look outside my apartment.
Also, maybe I should make a 5V battery backup for my Blitzortung receiver, then pray for a neighborhood-wide power outage.  Angel  I could get a lot of interesting data then!
RE: Identifying interference with oscilloscopes and software-defined radio - by djhuft - 2017-08-08, 02:58
  Possibility of contributing to a second-tier experimenta hardware / software effort? louloulou 0 4,100 2020-08-16, 19:04
Last Post: louloulou
  Identifying which controller I'm looking at Dale.Reid 3 18,341 2016-06-20, 14:19
  NeB Q: Will nearby FM Radio Cell towers cause problems br1ght 2 15,292 2015-09-18, 20:53
Last Post: br1ght
  Gain settings by software? PA4EME 4 29,357 2014-09-07, 21:14
