East Africa
(2017-10-30, 11:31)pasense Wrote: Thanks, we will up our ambition to ten stations.... We would be happy to talk to Egon Wanke!
Hello Nick,
I think you should contact Egon Wanke directly regarding setting up an east African network. Only two considerations from my side: the minimum of stations required to register a valid stroke is 8 in Amerika and 11 in Europe. So 5 would be a bit on the low side. Since these stations would be quite some dístance from each other, you would probably go for coverage and detection efficiency and not for very accurate location of each stroke. In this case, using the system with the optional low-pass filters is useful. With them you can cut out all frequencies say above 25 kHz which are useless anyway for long-range detection, but you would loose a bit of location accuracy, as I learned from Egon.
East Africa - by nvandegiesen - 2017-10-30, 09:52
RE: East Africa - by pasense - 2017-10-30, 11:31
RE: East Africa - by nvandegiesen - 2017-10-30, 12:26
RE: East Africa - by cutty - 2017-10-30, 13:08
RE: East Africa - by pasense - 2017-10-30, 16:51
  Lightning strikes displayed in South Africa GBeS29 3 16,764 2021-11-05, 09:31
Last Post: devilmaycry
  South East Asia possibilties Dan 0 2,952 2021-10-02, 11:43
Last Post: Dan
  Africa joseph.uzoagba@alphamead.com 8 37,113 2018-12-31, 16:49
Last Post: rogerpaulthompson
  Looking to setup station in South Africa rogerpaulthompson 45 210,678 2016-03-01, 13:43
