(2020-05-31, 06:11)gerbold Wrote:hi klaus thanks for reply yes i have registerd my station is 2712 so why its still blue ?? my pcb has stoped working for the moment but for now have been makeing two anttennas, all cabled with 1x e field and 1x h field 35cm dubble loop from copper pipeing on my water tank on small flat roof ,(2020-05-30, 15:56)GJ7DNI Wrote: will i only be see on map if a can stop the gps fault 1pps ? gps not seeing all sky but a lot of sat are green?Hi,
there are probably two parts of an answer.
1) May I assume you are station operator? If so, did you register your station? The colour of your username should switch from blue to green.
2) You should do something about the GPS availability - as I have to. While looking through a window, my GPS antenna sees a bit less than half of the sky. This leads to a GPS availability of about 85% and an unstable position detection. Without position the station does not send signals to the server. In my case I'd estimate this to be around 10 to 15 minutes an hour. With a clear view to the sky the GPS availability of the same antenna is close to 100%
Klaus
Any source for lightning strikes?
« Next Oldest | Next Newest »
Messages In This Thread |
Any source for lightning strikes? - by Johnlarry - 2019-04-15, 18:07
RE: Any source for lightning strikes? - by mwaters - 2019-04-15, 20:05
RE: Any source for lightning strikes? - by kevinmcc - 2019-04-21, 16:48
RE: Any source for lightning strikes? - by scilover - 2020-05-29, 09:54
RE: gps - by GJ7DNI - 2020-06-21, 19:22
RE: Any source for lightning strikes? - by mwaters - 2020-06-21, 20:10
RE: Any source for lightning strikes? - by gerbold - 2020-06-22, 06:03
Lightning strikes displayed in South Africa | GBeS29 | 3 | 16,765 |
2021-11-05, 09:31 Last Post: devilmaycry |
Detecting Lightning strikes on the opposite side of the earth ? | Michael.Sanders | 1 | 13,051 |
2014-10-28, 12:01 Last Post: Tobi |
