GPS died?
(2019-06-07, 14:46)readbueno Wrote: Hi All, I have a similar problem.
This appears to be something to do with the GPS Antenna. The red GPS blinks without the antenna and with one antenna I get sat data, but no pps and with another diferent antenna, pps data, but no sat data.
Apart from this the board appears to function correctly and it updated firmware with no problem.
I would like to get active again, but without further information about why this is happening I can not just keep buying different GPS Antennas until I get one that works.
Thank you in advance.
Kindest regards,
Brian.1856 Vilaboa.
Thanks Mike, Yes. I have tried resetting. The antennas were in the same place as the previous antenna and that worked ok.
I thought it was the actual GPS module, but that seems to work normally as long as no external antenna is plugged in.
It may be to do with the pre-amp in the antenna? Although it has 3.2 volts at the centre pin.
Brian.
GPS died? - by Snicker - 2014-08-01, 07:09
RE: GPS died? - by RichoAnd - 2014-08-01, 07:28
RE: GPS died? - by Snicker - 2014-08-01, 08:58
RE: GPS died? - by Dottore - 2014-08-01, 07:37
RE: GPS died? - by Tobi - 2014-08-01, 11:17
RE: GPS died? - by Snicker - 2014-08-01, 12:14
RE: GPS died? - by Snicker - 2014-08-22, 05:36
RE: GPS died? - by leon2017 - 2017-07-19, 08:27
RE: GPS died? - by Tobi - 2017-08-11, 09:40
RE: GPS died? - by Weather muurame - 2019-06-03, 18:34
RE: GPS died? - by readbueno - 2019-06-07, 14:46
RE: GPS died? - by readbueno - 2019-06-07, 15:19
RE: GPS died? - by mwaters - 2019-06-07, 16:55
RE: GPS died? - by readbueno - 2019-06-07, 17:01
RE: GPS died? - by mwaters - 2019-06-07, 14:52
RE: GPS died? - by mwaters - 2019-06-07, 16:07
RE: GPS died? - by readbueno - 2019-06-07, 16:42
RE: GPS died? - by Weather muurame - 2019-06-07, 16:49
