controller cable
Could someone give me a steer on what kind of cable to use for connecting the controller to my modem/router? Obviously ethernet, but should it be CAT5e network type?
Thanks, Jim[/size][/font]
Just Cat5 - without shield - often Cat5e is ok, but we have also seen noise problems because ground loops
Thanks. Is there a generally recognized maximum length for this cable?
Jim
100 feet
The specifications for 10/100BaseT are 100m on a cat. 5 cable.
Stations: 233
(2015-02-01, 16:52)RichoAnd Wrote: 100 feet
Sorry... 300 feet ~ 100m Blush
Note that I was speaking of the distance from the controller to the computer cum modem, not the distance from the controller to the amplifier/antenna. Can the distance from the controller back to the modem really be 100 m?? if so, that would be useful to me.
Thanks, Jim
I know, and yes 100m ~ 300ft is a norm and means between two peaces of hardware
I have the controler outdoor with a 60m cat5 cable, powered with an homemade PoE.
Stations: 8103223
  Max Cable Length rutrut 1 12,398 2022-12-26, 15:19
Last Post: dupreezd
