e-field antenna length question..
Greetings all!
I have a quick question in calculating the length of the e-field antenna.. (in order to enter it into the station details section)..
I want to put a few loops at the end of the copper wire antenna.. would the antenna length be whatever the length of the wire rod was BEFORE twisting the loops (longer), or just the length AFTER creating the loops (shorter)..
My gut feeling is that the loops are still considered part of the antenna length, even though they aren't straight.
Thanks everyone Cool
Station 1384
Lincoln NB, Canada
Stations: 1384
Correct - the entire length counts .... BUT it is not antenna length but the overall antenna capacity to the environment.
We're not talking about a meter but shorter If the wire is about 0,25mm² or more
(2015-08-25, 09:56)RichoAnd Wrote: Correct - the entire length counts .... BUT it is not antenna length but the overall antenna capacity to the environment.
Is there a formula one can apply, to calculate the effective length?  I like formulas..   Big Grin
Stations: 1384
Look here :
http://dl7ahw.bplaced.net/kapazitaet.htm
I use an 1m 0.05mm wire in an carbon-tube 5m above ground.
Thomas
Stations: 1006, 1305
I use 100mm of 2.5mm² copper electrical wire. Smile
(2015-08-25, 15:13)DelandeC Wrote: I use 100mm of 2.5mm² copper electrical wire. Smile
Thanks for that tip Idea
Stations: 1384
  Making a copper tubing H-field antenna Geewizard 3 20,209 2025-06-02, 18:02
  Max Cable Length rutrut 1 12,355 2022-12-26, 15:19
Last Post: dupreezd
  Blue e-field antenna question llowrey 2 22,019 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 27,440 2020-11-05, 15:48
  Can E-field antenna be casted in resin? OH4GRM 3 26,926 2020-06-01, 13:19
Last Post: dupreezd
