Fault LED indicates fault
(2016-09-15, 09:41)Bergkvar Wrote:
(2016-09-14, 11:00)elythomaslumber Wrote:
the other LED's? they ar ok
no interference.
Good luck!
73 de Hartmut / DK5LH
Stations: 1582
Fault LED indicates fault - by j82 - 2016-06-30, 08:55
Fault LED indicates fault - by DelandeC - 2016-06-30, 09:45
RE: Fault LED indicates fault - by j82 - 2016-07-01, 11:20
RE: Fault LED indicates fault - by LennartJ - 2016-09-13, 09:29
RE: Fault LED indicates fault - by Bergkvar - 2016-09-15, 09:41
RE: Fault LED indicates fault - by elythomaslumber - 2016-09-15, 16:33
RE: Fault LED indicates fault - by LennartJ - 2016-09-16, 12:01
RE: Fault LED indicates fault - by Tobi - 2016-09-20, 08:40
  Fault mode after big electrostatic discharges. ant01n3 1 538 2024-01-30, 22:55
Last Post: dupreezd
  fault led at first boot uvash 3 11,174 2021-11-18, 10:37
Last Post: aloha20
  How to get alerts of fault or missing GPS jchonig 2 7,964 2020-12-30, 18:23
