System Blue GPS problem
Steve,
If this is the problem, just update the firmware. It was fixed in Firmware 8.0 ("* fix: ignoring GPS messages from QZSS satellite"). I doubt you're running firmware that old though, so it might be another issue.
Do you have another GPS antenna you can try? I was using a cheap eBay antenna and losing the GPS fix quite regularly (availability on the controller page was about 60-80% most days). I had no errors in the log, apart from it noting that the GPS was unavailable. Swapped in another antenna from Adafruit which I'd used for a Raspberry Pi project, and all my problems went away.
This is the antenna I'm now using with no problems: https://www.adafruit.com/product/960
Stations: 1614
System Blue GPS problem - by Steve- - 2016-11-14, 23:51
RE: System Blue GPS problem - by DnH2016 - 2016-11-15, 03:33
RE: System Blue GPS problem - by DnH2016 - 2016-11-15, 03:36
RE: System Blue GPS problem - by Steve- - 2016-11-15, 04:51
RE: System Blue GPS problem - by Steve- - 2016-11-15, 05:02
RE: System Blue GPS problem - by piepants - 2016-11-15, 05:03
RE: System Blue GPS problem - by Steve- - 2016-11-15, 05:26
RE: System Blue GPS problem - by DnH2016 - 2016-11-15, 05:37
RE: System Blue GPS problem - by DnH2016 - 2016-11-15, 05:50
RE: System Blue GPS problem - by DnH2016 - 2016-11-15, 05:59
RE: System Blue GPS problem - by piepants - 2016-11-15, 06:23
RE: System Blue GPS problem - by Steve- - 2016-11-15, 08:49
RE: System Blue GPS problem - by DnH2016 - 2016-11-15, 09:35
  Problem after updating firmware. blue 8.32b readbueno 30 127,407 2017-09-11, 23:51
Last Post: readbueno
