Update error
Hi all,
I'm a new member here
And I have installed MyBlitzortung
But the update I get this error  Huh
2017-04-05 15:51:22 +    0ms |
2017-04-05 15:51:22 +    0ms | ***** Getting lightning data from blitzortung.org *****
2017-04-05 15:51:22 +    1ms | Information: PHP Execution timeout is 300s  --> Fine Smile *** Setting MyBlitzortung timeout to: 55s
2017-04-05 15:51:22 +    2ms | Waiting 4 seconds, to avoid too high load on Blitzortung servers ...
2017-04-05 15:51:22 + 4003ms |
2017-04-05 15:51:22 + 4003ms | === Strikes ===
<br />
<b>Warning</b>:  preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead in <b>/home/kampe25/domains/meteosauwerd.nl/public_html/Onweerdetectie/includes/classes/FilesDownload.class.php</b> on line <b>67</b><br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
2017-04-05 15:51:22 + 4018ms | Last strike: 1970-01-01 00:00:01 *** Loading 13 files from 2017-04-05 13:50:00 to 2017-04-05 15:50:00 *** This is update #7
2017-04-05 15:51:22 + 4018ms | Lines: 0 *** Size: 0kB *** New Strikes: 0
2017-04-05 15:51:22 + 4022ms |
2017-04-05 15:51:22 + 4022ms | === Stations ===
2017-04-05 15:51:22 + 4022ms | No update. Last update 262 seconds ago. This is normal and no error message!
2017-04-05 15:51:22 + 4022ms | === Raw-Data ===
2017-04-05 15:51:22 + 4022ms | Not implemented!
2017-04-05 15:51:22 + 4024ms |
2017-04-05 15:51:22 + 4024ms | === Strike alerts ===
2017-04-05 15:51:22 + 4027ms |
2017-04-05 15:51:22 + 4027ms | Import finished. Exiting...
Who has a solution
Thanks,
Piet
Stations: 1812
(2017-04-05, 16:01)giantocr Wrote: Hi all,
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Who has a solution
Thanks,
Piet
Have now solved the problem.
My FilesDownload.class.php was an old version.
Did this updated and it now works properly.
Piet
Stations: 1812
