lightningmaps.org - Archives:Search don't show points on map
Bug
After login and selecting range to show strokes I can't see any point on the map. Below attached screenshot and link to web page:
http://www.lightningmaps.org/blitzortung...t=&lang=en
What was wrong? Is problem with googlemaps API or with my configuration?
best regards
Krzysztof
best regards
Krzysztof SP7SZL
Stations: 1834
(2017-05-24, 11:32)Elint Wrote: After login and selecting range to show strokes I can't see any point on the map.
best regards
Krzysztof
Hi Krzysztof,
I have the same problem here. I guess it has to do something with API changes.
Stations: 1905
same problem here ;(
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 14,591 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 19,420 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 26,722 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 24,449 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 16,860 2024-07-01, 07:29
Last Post: Blubbel
