Linear power supply
At least you aren't under power, but I don't know if over is good either... I wonder if it makes any difference?
I found that the USB voltage can't be adjusted on the unit I got, but there's another DC output that can be. I tested that one, and it's 5 volts on the nose. I just need to get an adapter for the plug that will connect to a USB plug. (Already have one on order)
What kind of power supply are you using?
Stations: 1955
Linear power supply - by JupiterJoe - 2017-08-30, 18:24
RE: Linear power supply - by kriu - 2017-08-30, 19:49
RE: Linear power supply - by JupiterJoe - 2017-08-30, 20:47
RE: Linear power supply - by kriu - 2017-08-30, 21:26
RE: Linear power supply - by JupiterJoe - 2017-08-31, 01:23
RE: Linear power supply - by cutty - 2017-08-31, 02:57
RE: Linear power supply - by kriu - 2017-08-31, 08:35
RE: Linear power supply - by pasense - 2017-08-31, 09:22
RE: Linear power supply - by allsorts - 2017-09-11, 19:13
RE: Linear power supply - by pasense - 2017-09-11, 14:52
RE: Linear power supply - by kriu - 2017-09-11, 19:31
RE: Linear power supply - by allsorts - 2017-09-17, 19:05
RE: Linear power supply - by readbueno - 2017-09-18, 09:07
RE: Linear power supply - by allsorts - 2017-09-22, 23:14
RE: Linear power supply - by kriu - 2017-09-19, 20:43
RE: Linear power supply - by RichoAnd - 2017-09-19, 21:43
RE: Linear power supply - by pasense - 2017-11-07, 13:45
RE: Linear power supply - by readbueno - 2017-11-07, 14:25
RE: Linear power supply - by pasense - 2017-11-07, 14:50
RE: Linear power supply - by allsorts - 2017-11-07, 17:36
RE: Linear power supply - by AlliPlatt - 2020-04-20, 17:42
RE: Linear power supply - by hazelnut - 2022-02-27, 08:22
RE: Linear power supply - by hazelnut - 2022-02-28, 11:04
RE: Linear power supply - by hazelnut - 2022-02-28, 12:25
RE: Linear power supply - by dupreezd - 2022-02-28, 18:21
RE: Linear power supply - by hazelnut - 2022-03-01, 02:22
  Several questions about the circuit protection that using linear power supplies Jand 3 19,491 2017-12-22, 23:03
Last Post: allsorts
