GPS troubles with my blue box
Hello
since a few hours my blue sys can't find any satellites. The blue GPS indicator on the frontside illuminates for approx. 1 sec, the pauses for approx. 2 sec.
No PPS pulse. Antenna device is MEDIATEK. Any hints what is going wrong here? Had the same troubles already some weeks ago but they disappeared suddenly.
Hans
Cheers Hans
Stations: 1671
(2017-12-28, 15:53)hazet_CHAM Wrote: Hello
Hans
Sometimes there is not a good combination of Satellites!
It may get better in a few minutes or so!
Brian. 1856.
(2017-12-28, 16:19)readbueno Wrote: Sometimes there is not a good combination of Satellites!
Brian. 1856.
True! But perhaps relocating the GPS antenna would be in order. You have to move it around to different locations, to maximize the number of satellites it finds.
Mine is on top of a basement wall up against the inside of the East wall. But outdoors on the South side of the house would likely be the optimal location for it.
IF at all possible and easily available, I'd try another patch antenna.  Or get it further away from buildings.  Mine worked in doors on the dining room table during "test" conditions (i.e. until my wife told me to box it up and move it) so it may work inside a one story wooden building, but the signal quality went way up when I did get the antenna outside.
Stations: 976, 1505
  GPS antenna SYSTEM BLUE ! IK1TTD 9 74,864 2020-06-03, 12:16
Last Post: GJ7DNI
  Reactivating an old Green PCB 6.8 USB - troubles Alexandre.Costa 8 62,210 2017-07-19, 16:23
Last Post: Alexandre.Costa
  System Blue GPS problem Steve- 12 84,569 2016-11-15, 09:35
Last Post: DnH2016
  System Blue GPS: Unknown sentence mhbeach 6 52,631 2016-06-22, 09:02
