lightningmaps.org station - last signal spectrum plot different
Greetings,
I updated my Blue to firmware 8.4 last night.  Last night I also noticed on my
lightningmaps.org - station tab - Last Signal window that the signal spectrum is now
dominated by the electrical system 60-Hz and I'm sure the first few
harmonics too.  The real signal spectrum is hardly visible near the bottom of the plot.
It appears to be a spectrum scaling change somewhere perhaps.  The spectrum also appears similar on
several other Blue stations pages.  Several Red stations spectrum I
checked appear normal and not dominated by the 60-Hz signal.  Not a big deal but
something changed, perhaps only for the system blue stations?
Jim, N8OQ
Stations: 1660
(2018-01-19, 14:39)VA_LM_Blue Wrote: Greetings,
Jim, N8OQ
Yes I have the same!
Brian 1856.
Yes, here also. It appears that @Tobi has improved the vertical scaling somehow.
I think that the 60 Hz bars might be useful when moving the antennas, that is, to find a place away from house wiring and power lines.
I wonder if those bars will drop when I finally change to shielded cable to the H-field amp, and later to shielded loops.
In any case, the new firmware really improved the performance of my station. :-)
  Station Moved Country and Showing Wrong on LightningMaps Dave.Auld 5 5,259 2026-02-14, 21:27
Last Post: Dave.Auld
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 13,832 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 18,680 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 25,337 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 23,305 2024-07-06, 17:17
Last Post: gerbold
