Hi there!
i am a new member of Blitzortung.org and have a few queries which I would appreciate your help on.
i have been using the app on my Galaxy Note 8 and Note 3 for about 2 or 3 years, can someone tell me the significance of the numbers in the coloured square on the map.
I would also like to set up a recording station here in Swansea,UK; how does one get hold of the latest Blitzortung euipment please?
Cheers,
westernslade5
Threads: 55
2018-05-27, 22:18
(This post was last modified: 2018-05-27, 22:20 by cutty.)
(2018-05-27, 21:32)westernslade5 Wrote: Hi there!
Cheers,
westernslade5
Which app are you referring to
The Approved Apps are all third party: https://www.lightningmaps.org/apps?lang=en
How to become an operator: http://en.blitzortung.org/cover_your_area.php
Read thoroughly, and be sure to read both the
Project Description - (14. February 2016, 11:10)
Assembly Instructions System Blue - (under developement)
referred to on the page.
Threads: 13
Threads: 37
(2018-05-27, 21:32)westernslade5 Wrote: i have been using the app on my Galaxy Note 8 and Note 3 for about 2 or 3 years, can someone tell me the significance of the numbers in the coloured square on the map.
Do you mean these colored squares in the Blitzortung Lightning Monitor Android app?
Put simply, the numbers are the number of strokes in that area in the time indicated by the color of each square.
Cheers,
westernslade5
Thanks to you both for the information, most helpful.
