New Blue Station No Signals on E-Field
Hello.
Recently a friend put up a new station in Athens Greece (Station 2326)
The problem is that the station cannot probe signals on e-field.
Since now we had done the following actions:
Reflash firmware (older and newer) -No go
Change the e-field antenna with another from other station - No go
Triple settings check. - no go
Check cables , psu etc.
The only error i see in debug log is the following,
2018-12-16 06:42:20  141.9 | ADC: Alignment error 1 #1
2018-12-16 06:42:21  142.9 | ADC: Alignment error 2 #2
2018-12-16 06:42:26  147.9 | ADC: Alignment error 2 #1
2018-12-16 06:42:39  160.8 | ADC: Alignment error 1 #1
2018-12-16 06:42:50  171.7 | ADC: Alignment error 1 #1
2018-12-16 06:43:07  190.0 | ADC: Alignment error 1 #1
2018-12-16 06:43:17  199.9 | ADC: Alignment error 1 #1
2018-12-16 06:43:34  216.8 | ADC: Alignment error 1 #1
2018-12-16 06:43:35  217.8 | ADC: Alignment error 1 #2
2018-12-16 06:43:37  219.8 | ADC: Alignment error 1 #1
2018-12-16 06:43:43  225.7 | ADC: Alignment error 1 #1
2018-12-16 06:44:01  243.6 | ADC: Alignment error 1 #1
Is there something else we should check - try ???
Possibly Related Threads...
  Blue H field Ferrite antenna in L or Delta shape? nellyt 8 13,226 2017-03-30, 03:06
Last Post: Mike6158
  H-Field antenna for system BLUE michael1608 8 11,375 2016-10-21, 22:45
Last Post: kevinmcc
  H-field PCB 16.x sys Blue EricJ 4 6,528 2016-09-04, 13:50
Last Post: RichoAnd
