2019-01-10, 04:31
The docs say:
I've got PCB 17.1 2016-03-20 (from the overall PCB 20.6) and can't find any obvious location to add the solder bridge, is this still required for current revisions, and if so where do you place it?
Also, for the ground terminal on the case, do you need to solder a connection to the 19.x PCB somewhere for good contact or is it sort-of connected via the case -> Ethernet jack contact?
Quote:Due to a small manufacturer's breakdown on Panel 20.5, the printed circuit board next to the E-field preamplifier is not connected to the input of the E-field preamplifier. Here, either a small solder bridge must be set or a corresponding antenna must be connected to the input.
