Green system
I read several times on this forum that the GREEN system will stopped soon. Is this true ? Is there an ending date ?
I ask this question because I have the opportunity to buy several used green stations.
Thanks for your answer.
Best regards,
Alexandre.
Stations: 507
(2019-10-04, 15:27)meteovergne Wrote: Hi,
Best regards,
Alexandre.
Alexandre,
My last information is that the server still accepts Green Data, and there is no firm decision to 'drop"such data.  However Green is obsolete, and no longer supported.  The Green data is liimited for any future use, especially with other lightning parameters outside of detection and limited accurate locating.  It is somewhat like comparing a 15cm black and white air signal television with a 150cm Digital HD TV.  Green systems work extremely well within their design and technology limitations. They are what they are, however.
Stations: 689, 791, 1439
that's right, what Mike said. We keep the green stations running, but we do not want to support these stations any further. The hardware and the tracker software are completely outdated. Only fragments of the signals are transmitted. You need a permanent running PC, etc.
/Egon
Stations: 753, 762, 1403
Thanks for your answer. valentines day gifts for her
Best regards,
Alexandre.
Alexandre,
Thanks for this - much appreciated!
Thank you all for your responses.
Best regards,
Alexandre
Stations: 507
(2020-04-08, 19:45)meteovergne Wrote: Hi,
Best regards,
Alexandre
Hi i have a green Version and want to update to a blue one.
Is there any way to upgrade to the new board?
Best regards
Horst
Stations: 146
Best regards,
Alexandre
Best regards
Horst
Green owners are first priority... but you must:
Send an email directly to Egon.
Remind him you're a Green Owner upgrading, with Green stadion number
(if you've changed email addresses (different than original emkail address, might incklude  "originally registered email:"  but my   "current correct email")
  System Green for FREE + postage. SalesJam 6 2,623 2020-04-18, 19:33
Last Post: SalesJam
  System green still usable RobertKi 4 10,495 2017-06-25, 04:45
Last Post: MooreGeo
  Green System Lightning Strike Counts Low Kalamara 6 15,263 2016-10-12, 06:35
Last Post: piepants
Lightbulb Fixed: Problem with System Green & Windows Tracker MuellerJ 1 5,500 2016-09-22, 19:03
Last Post: MuellerJ
  Green System PCB 6 Ver 8.0. No Green Light Kalamara 12 29,574 2015-09-18, 22:40
Last Post: PetrosKa
