2020-08-27, 17:04
(This post was last modified: 2020-08-27, 18:42 by cutty.)
I just signed up to the forum and it asks a question referencing the "cover your area page"
https://www.blitzortung.org/en/cover_your_area.php
problem is, at least one of the questions quotes a sentence from that page, and there's no such sentence. it's the one about xxxxxxxxxxxxxxx
fortunately I was able to get the forum to ask me a different question and complete the registration.
thanks
Paul
Threads: 4
2020-08-27, 17:10
(This post was last modified: 2020-08-27, 18:43 by cutty.)
(2020-08-27, 17:04)speculatrix Wrote: Hi,
I just signed up to the forum and it asks a question referencing the "cover your area page" https://www.blitzortung.org/en/cover_your_area.php
problem is, at least one of the questions quotes a sentence from that page, and there's no such sentence. it's the one aboutxxxxxxxxxxxx
thanks
Paul
The sentence and answer is there.
2020-08-27, 17:18
Edit Reason: By Admin to remove registration answer clues
(2020-08-27, 17:10)dupreezd Wrote: (2020-08-27, 17:04)speculatrix Wrote: problem is, at least one of the questions quotes a sentence from that page, and there's no such sentencexxxxxxxxxxxxxxxxxxxx
I just tried going to the registration page in an incognito tab
It asks this:
A 'lightning discharge impulse' is a _ _ _ _ _ _.
if you search this page: https://www.blitzortung.org/en/cover_your_area.php
for the word "xxxxxx", I'm fairly sure that the sentence above doesn't appear.
I tried "xxxxxx" and it didn't work.
Threads: 56
2020-08-27, 18:34
(This post was last modified: 2020-08-27, 18:48 by cutty.)
Try reading the page, instead of looking for
"the sentence above"...
you are indeed correct... the 'sentence' does not exist on the page...the questlion does NOT reference a sentence. It references the page.
HOWEVER: Having written the questtion, I can assure you the answer is there. Hundreds of folks have obviously found it.
Thread closed. and posts edited above.
