Same stations listed multiple times in different regions
Hi there.
just looking at the UK station list here:
https://www.blitzortung.org/en/station_l...t_rows=100
I noticed a number of stations are listed as UK Country but 2-4 times in different Regions. is this a known bug?
Regards Simon
https://www.conligwx.org
Stations: 1283, 3079
(2021-01-19, 10:07)Toxic Wrote: Hi there.
Some Stations are reporting in support of multiple regions. NOT a bug.
This is deliberate. This is assigned by the main servers. Also before someone asks again... the numbers for such stations are reported per/region, not a 'total' of 'all' signals from that station. Such stations must be checked by 'region', rather than just requesting a station number, expecting 'totals', etc.
Thanks for the update.
Regards Simon
Hi
User - Sareme
Station - 2365
Area - Europe Cyprus
Fault - Station Active:   Yes/no reception
Receiving signals OK but all parameters are at 0 on the network stats page. Last signal received   2021-04-06 08:05:17 UTC
Regards
AW
MOD NOTE: originally posted in wrong board
Stations: 2365
(2021-04-26, 04:46)Sareme Wrote: Hi
User - Sareme
Station - 2365
Regards
AW
Here is a case of looking at LIGHTNING MAPS.ORG  instead of the Blitzortung site, where 2365 data is processed.
2365 supports and reports to 3 regions, and doing well:
2365 Pano Arodes Cyprus Europe 1 Running 2021-04-26 11:44 16477 9591 350 185    172 km 3765 km
2365 Pano Arodes Cyprus Asia 1      Running 2021-04-26 11:44 16493 9964   15     7    183 km 1236 km
2365 Pano Arodes Cyprus Africa 1   Running 2021-04-26 11:44 16491 8391     4      2  2032 km 4656 km
DO NOT rely on Lightningmaps.org for real-time, or correct information especially in such cases.  It does NOT currently interface rapidly or correctly with much of the 'newer' database and algorithm processing on the Blitzortung servers.
  Remove Regions. gb3bs_Bristol 2 13,230 2025-09-24, 11:47
Last Post: gb3bs_Bristol
Photo stations not listed in statistics hans.mayer 2 22,935 2021-11-10, 06:41
Last Post: selenasadler
  My station listed as offline. But it's working! Geewizard 0 16,916 2015-01-04, 16:00
Last Post: Geewizard
