Servers Damaged (Mostly affecting LMO ?)
(2021-04-05, 11:38)Weather muurame Wrote: Is this fire caused that issue:
***** Getting lightning data from blitzortung.org *****
2021-04-05 14:34:54 +    0ms |
2021-04-05 14:34:54 +  88ms | Information: PHP Execution timeout is 120s  --> Fine Smile *** Setting MyBlitzortung timeout to: 55s
2021-04-05 14:34:54 +  89ms |
2021-04-05 14:34:54 +  89ms | === Strikes ===
2021-04-05 14:34:54 +  197ms | Last strike: 2018-05-04 07:32:38 *** Loading 13 files from 2021-04-05 09:30:00 to 2021-04-05 11:30:00 *** This is update #541775
2021-04-05 14:34:54 + 2387ms |  Downloading file /2021/04/05/11/30.log: Error (401 Unauthorized), 2nd try : Error (401 Unauthorized).
2021-04-05 14:34:54 + 2387ms | Lines: 0 *** Size: 0kB *** New Strikes: 0
2021-04-05 14:34:54 + 2396ms |
2021-04-05 14:34:54 + 2396ms | === Stations ===
2021-04-05 14:34:54 + 2588ms | UPDATE ERROR: [stationdata] Download of station data failed. 401 Unauthorized
2021-04-05 14:34:54 + 2589ms | ERROR: Couldn't get file for stations! Code: 401 Unauthorized
Maybe ... but there may be another issue:
If you are station 804 Muurame (RED )Finland
Europe 1
Running ... so the Blitzortung server sees your station
BUT the server has received NO signals from 804 since
2019-06-03 16:50
which means you likely are NOT in the LMO database, and there is no signal data to download from the Blitzortung database either.
RE: Servers Damaged (Mostly affecting LMO ?) - by cutty - 2021-04-05, 12:31
