[Iframe] MapStyleRangeValue not working
I'm using the following iframe link values:
NavigationControl=0
FullScreenControl=0
Advertisment=0
Cookies=0
MapStyle=2
MapStyleRangeValue=1
CirclesCheckboxChecked=1
CirclesRangeValue=5
AudioCheckboxChecked=1
AudioRangeValue=10
LightningCheckboxChecked=1
LightningRangeValue=6
However it ignores the MapStyleRangeValue and thus shows the map in a very dark state. If i then activate the hamburger menu and just moves the slider 1 number to either side, it updates the rendering so it seems that the javascript code isn't reading the MapStyleRangeValue url parameter properly when the website is first initialized.
Is there any fix for this? Otherwise it's working great!
I just tried this again to see if there has been any updates. Still the same issue. The MapStyleRangeValue is ignored. Here's a test link:
https://map.blitzortung.org/?NavigationC...86/-4.8268
To make it brighter, i have to open the top right corner menu and adjust the slider to the left of map styles.
  Display icon at certain position on iframe danavner 1 4,903 2021-07-23, 09:42
Last Post: AlixNevison
