Controller 10.4 - Two Amplifiers?
I see from the document that Controller 10.4 has two amplifier input connectors on the board. Is it possible to run two amplifiers off the one controller, say one H and one E field?
Andrew
(2014-06-01, 22:44)AndrewIC Wrote: Hello,
Andrew
Oh Yes... works great adding boards 13 & 14.
Thanks my kit with H-field amp just arrived Smile
(2014-06-21, 13:49)AndrewIC Wrote: Thanks my kit with H-field amp just arrived Smile
Go For It!...
Over here in region 3 we're trying to get all to run H field on amp1 and E field on amp 2, so if they have issues, we can all work with the same "Channel Colors" on displays... Smile So if they're running E field only, we're suggesting they connect it to amp 2...
  Firmware 10 on System Red PCB 10.5 - firmware bug ??? mmlightning 1 11,340 2025-02-27, 08:37
