Pics of your hardware - Printable Version
+--- Thread: Pics of your hardware (/showthread.php?tid=1825)
Pages: 1 2
RE: Pics of your hardware - ropske - 2016-08-03
(2016-08-03, 12:44)DelandeC Wrote: Hello,
Mine is made of pvc wterpipe with two closures on each side. A hole has been drilled in one closure so that I could install a cable gland.
Diameter 40mm.
Everything was found in a "Brico" in Belgium Wink
Found it in the belgium hubo shop  Big Grin
Thank you
RE: Pics of your hardware - Jorgeminator - 2016-08-04
Diameter 40mm.
Thank you
Mine was made roughly in the same way. Glad you found the parts needed.  Smile
